メインコンテンツにスキップ
Apple TV 4K Logic Board Replacement
必要な工具と部品
  1. Apple TV 4K Logic Board Replacement, Logic Board: 手順 1、 1の画像 1
    • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
    • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
  2. Apple TV 4K Logic Board Replacement: 手順 2、 2の画像 1 Apple TV 4K Logic Board Replacement: 手順 2、 2の画像 2
    • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
    • Four 10 mm screws
    • Lift and remove the heat sink assembly from the device.
  3. Apple TV 4K Logic Board Replacement: 手順 3、 2の画像 1 Apple TV 4K Logic Board Replacement: 手順 3、 2の画像 2
    • Use plastic spudger to pull up on all three antenna connectors to remove them.
    • Remove rubber piece from front side of device.
  4. Apple TV 4K Logic Board Replacement: 手順 4、 1の画像 1
    • Unscrew the following screws holding the logic board in place using the T7 Torx:
    • Two black 3 mm screws
    • Two silver 4 mm screws
  5. Apple TV 4K Logic Board Replacement: 手順 5、 3の画像 1 Apple TV 4K Logic Board Replacement: 手順 5、 3の画像 2 Apple TV 4K Logic Board Replacement: 手順 5、 3の画像 3
    • Use a spudger to pry up logic board. Try lifting it up from the front side.
    • Remove logic board and set aside.
終わりに
8 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Keenan Barber
メンバー登録日: 10/04/18
1,159 ポイント
3のガイドは作成済み
チーム
UW Stout, Team S6-G3, Ogden Fall 2018 UW Stout, Team S6-G3, Ogden Fall 2018人のメンバー
UWSTOUT-OGDEN-F18S6G3
4 メンバー
15のガイドは作成済み
8 件のコメント
Where does one get a new logic board??
MP94025 - 返信
Any idea on where I can purchase. new logic board?
tylerchumchal - 返信
Where do you buy the board…….
Andy Grichtmeier - 返信
Good job on showing how to remove and replace logic board. Now as the other three commentators have asked
, where can you buy another one or is an exercise in futility
Kanehoe - 返信
Hm. Has anyone’s Apple TV 4k logic board failed?
oTWR - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 30
過去 30 日: 122
今までの合計 8,058
