メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
    • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
  2. Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
    • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
  3. Use a philips screwdriver to remove the metal heat sink.
    • Use a philips screwdriver to remove the metal heat sink.
  4. The logic board is held in place by the power supply connector, but that's no problem for our spudger. A quick flick and the logic board is free. The logic board is held in place by the power supply connector, but that's no problem for our spudger. A quick flick and the logic board is free.
    • The logic board is held in place by the power supply connector, but that's no problem for our spudger. A quick flick and the logic board is free.
  5. You may now be able to remove the power supply with a spudger The rating of the power supply is 3.4V at 1.75A, which is identical to the 2nd Gen Apple TV's 5.95 watts.
    • You may now be able to remove the power supply with a spudger
    • The rating of the power supply is 3.4V at 1.75A, which is identical to the 2nd Gen Apple TV's 5.95 watts.
まとめ
8 の人々がこのガイドを完成させました。
Vincent Monteil
メンバー登録日: 2013年07月06日
6,241 ポイント
19のガイドは作成済み
you forgot to add the power supply is held by 2 tiny torx screw
morpheuse - 返信
Successfully sourced a new power supply for our 3rd generation after the last one was destroyed ironically by Apple juice. Sourced from China and replaced- presto!! It's working- all for $14.95
rcbakes30 - 返信
Where? I need on badly! Can you send me / Post here a link?
jakesterage -
please, and where could be find the part, the power supply for AppleTV 3rd generation?
foxy72 - 返信
Hi, i have a 3rd gen Apple TV and I have problems with it, it doesn't turn on I don't now if it's the power supply or it is &&^&@@ up how can I figure out if it is the power supply and in that case where can I found one
ilichcorcegatreep - 返信
I Olson have a Apple TV box an older version how can I test if it is working
Mike baker - 返信
In case the LED light does not glow even after restoring by remote or iTune then problem is with SMPS unit. Get a new SMPS unit and replace it yourself !
a_gowardhan - 返信
Where can we buy the Power supply?
Tulio Guimaraes - 返信
search for OT9031 from ACBEL POLYTECH or 614-0482 from Apple.
Felipe -
mine burned Fuse and L1 if I new L1 value I would try to find it and replace
Felipe - 返信
コメントを追加する
統計データを表示:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 106
今までの合計 14,799
