メインコンテンツにスキップ
Apple TV 2nd Generation Power Supply Replacement
必要な工具と部品
  1. Apple TV 2nd Generation Power Supply Replacement, Power Supply: 手順 1、 2の画像 1 Apple TV 2nd Generation Power Supply Replacement, Power Supply: 手順 1、 2の画像 2
    この手順で使用する道具:
    Metal Spudger
    $2.99
    購入する
    • As the Apple TV doesn’t have any visible screws or point of entry, the first step is to use a couple of metal spudgers to carefully loosen and remove the rubber base from the upper case.
    • Upon opening the Apple TV, the most noticeable and largest parts will be the heat sink and power supply.
  2. Apple TV 2nd Generation Power Supply Replacement: 手順 2、 3の画像 1 Apple TV 2nd Generation Power Supply Replacement: 手順 2、 3の画像 2 Apple TV 2nd Generation Power Supply Replacement: 手順 2、 3の画像 3
    この手順で使用する道具:
    Phillips #1 Screwdriver
    $5.49
    購入する
    • Using a #1 Phillips screwdriver, remove the screws holding the heat sink in place.
    • Remember, there are also screws hidden underneath the thermal pad.
    • Next, use a metal spudger to gently pry the logic board up and out of the device. This will allow easier access to the power supply.
  3. Apple TV 2nd Generation Power Supply Replacement: 手順 3、 2の画像 1 Apple TV 2nd Generation Power Supply Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • The power supply is attached at three different points: the logic board/power supply connector, two screws and a heavy piece of tape, located underneath the power supply.
    • Locate the connector attaching the power supply to the logic board. Using a pair of tweezers, gently remove the connector from the power supply.
    • Using a #1 Phillips screwdriver, remove the two screws located toward the front of the device.
  4. Apple TV 2nd Generation Power Supply Replacement: 手順 4、 2の画像 1 Apple TV 2nd Generation Power Supply Replacement: 手順 4、 2の画像 2
    • Using a nylon spudger around the edge, gently work the power supply up and out of the case.
    • Place the replacement power supply in the now empty spot.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Deanna Rice
メンバー登録日: 09/28/17
261 ポイント
2のガイドは作成済み
チーム
University of Maine, Team S1-G2, Diaz Fall 2017 University of Maine, Team S1-G2, Diaz Fall 2017人のメンバー
UMAINE-DIAZ-F17S1G2
4 メンバー
4のガイドは作成済み
2 件のコメント
There is actually no need to take out the heat sink, just open the bottom, unscrew the power connector, unplug the 8-pin connector from power supply and the power supply is free.
skvarlamatus - 返信
My power supply of apple tv 2nd gen is damaged, it is not available?
Ceporce - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 1,749
