メインコンテンツにスキップ
Apple TV 2nd Generation Heat Sink Replacement
必要な工具と部品
  1. Apple TV 2nd Generation Heat Sink Replacement, Heat Sink: 手順 1、 2の画像 1 Apple TV 2nd Generation Heat Sink Replacement, Heat Sink: 手順 1、 2の画像 2
    この手順で使用する道具:
    Metal Spudger
    $2.99
    購入する
    • The Apple TV has no visible screws or visible areas of entry. Therefore, we must first begin by using a metal spudger or two and inserting them between the rubber-coated base and the upper case
    • With some careful maneuvering, the Apple TV base should pop off.
    • A large pink square will be visible once the base is removed. This is the thermal pad.
    • The heat sink is the large black piece holding the thermal pad in place. The heat sink is metal and it’s purpose is to draw heat away from the chips inside the device.
  2. Apple TV 2nd Generation Heat Sink Replacement: 手順 2、 3の画像 1 Apple TV 2nd Generation Heat Sink Replacement: 手順 2、 3の画像 2 Apple TV 2nd Generation Heat Sink Replacement: 手順 2、 3の画像 3
    この手順で使用する道具:
    Phillips #1 Screwdriver
    $5.49
    購入する
    • The thermal pad should come off in one piece. After it is off, use a Phillips screwdriver to remove the five screws holding the heat sink in place.
    • Once the screws are removed, it will be easy to separate the heat sink from the PCB. You will also notice a second thermal pad located under the heat sink. You may remove this pad as well.
    • Once the pads are removed, they may either be reattached to a new heat sink or new thermal pads may be placed on the new heatsink.
終わりに
作成者
2人の作成者と共同で作成されました。
Areej Bashawiri
メンバー登録日: 09/28/17
201 ポイント
2のガイドは作成済み
チーム
University of Maine, Team S1-G2, Diaz Fall 2017 University of Maine, Team S1-G2, Diaz Fall 2017人のメンバー
UMAINE-DIAZ-F17S1G2
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 18
今までの合計 691
