Rotate the display so the legs of the display are now facing you
Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
Now that the screw has been removed, slide the panel towards your body and lift it out.
You may need to remove the clear USB port cover to remove the metal EMI shield.
To remove the USB port, remove these four screws holding down the port and metal brackets.
There may be a zip tie you need to cut that is attaching the USB unit to the display
このガイドを埋め込む
ご自身のサイト/フォーラムに小さなウィジェットとしてこのガイドを埋め込むには、サイズを選択し下のコードをコピーしてください。
プレビュー
