メインコンテンツにスキップ
はじめに
Replacing the ADC cable. This cable provides connection to the computer, along with supplying power to the display.
パーツ
パーツは指定されていません。
  1. Lay the display facing down with the stand away from you. Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Rotate the display so the legs of the display are now facing you
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  5. The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  6. Now locate and remove the lone Phillips screw holding the EMI shield to the display
    • Now locate and remove the lone Phillips screw holding the EMI shield to the display
  7. Now that the screw has been removed, slide the panel towards your body and lift it out. You may need to remove the clear USB port cover to remove the metal EMI shield.
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
  8. To remove the USB port, remove these four screws holding down the port and metal brackets.
    • To remove the USB port, remove these four screws holding down the port and metal brackets.
    • There may be a zip tie you need to cut that is attaching the USB unit to the display
  9. Remove the cable from the logic board that is connecting the USB port.
    • Remove the cable from the logic board that is connecting the USB port.
  10. Remove the USB port
    • Remove the USB port
  11. Remove these four screws holding down the base of the swing arm to the display and remove it
    • Remove these four screws holding down the base of the swing arm to the display and remove it
  12. Remove the four screws holding down the ADC cable to the display
    • Remove the four screws holding down the ADC cable to the display
  13. Remove the three connections  that connects the ADC assembly to the logic board and screen
    • Remove the three connections that connects the ADC assembly to the logic board and screen
  14. Remove and replace the ADC cable assembly.
    • Remove and replace the ADC cable assembly.
終わりに
Andrew Tsao
メンバー登録日: 2010年01月19日
159 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 3-20, Maness Winter 2010 Cal Poly, Team 3-20, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S3G20
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 1,548
