メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. この手順は未翻訳です。 翻訳を手伝う。
    First remove the three 2mm hex screws from the top of the monitors stand. Then, remove the four 2mm hex screws on the corners of the back panel.
    • First remove the three 2mm hex screws from the top of the monitors stand.
    • Then, remove the four 2mm hex screws on the corners of the back panel.
    • Finally, the back panels can be removed by pulling the main cable through the opening and sliding the panels away.
  2. この手順は未翻訳です。 翻訳を手伝う。
    Remove the metal backing.
    • Remove the metal backing.
    • Remove the single screw at the top and the two screws at the bottom of the monitor with #2 philips head screwdriver.
    • With the screws removed, push metal backing toward back of monitor to release its clips and pull away.
  3. この手順は未翻訳です。 翻訳を手伝う。
    Now, with the circuitry exposed, locate the CCFL inverter board.
    • Now, with the circuitry exposed, locate the CCFL inverter board.
    • Look for the smaller of the two circuit boards with two wires and a ribbon cable running out of it.
  4. この手順は未翻訳です。 翻訳を手伝う。
    Now the connections from the board need to be removed.
    • Now the connections from the board need to be removed.
    • Remove the two cables on the left side of the board, using a pin to insert into the two small holes and then pull out.
    • This step may be easier with two people.
    • Do not insert pin in hole with force or you risk damaging the connector.
  5. この手順は未翻訳です。 翻訳を手伝う。
    Remove the ribbon cable on the right side of board by pulling it away from the LCD main board with hand.
    • Remove the ribbon cable on the right side of board by pulling it away from the LCD main board with hand.
  6. この手順は未翻訳です。 翻訳を手伝う。
    Remove the top philips head screws holding the board to the monitor with #2 philips head screwdriver.
    • Remove the top philips head screws holding the board to the monitor with #2 philips head screwdriver.
  7. この手順は未翻訳です。 翻訳を手伝う。
    Remove the bottom philips head screw and pull the CCFL Inverter board away from monitor.
    • Remove the bottom philips head screw and pull the CCFL Inverter board away from monitor.
    • To replace this part with a new one, simply follow these directions in reverse using the new board.
ゴール
ある他の人がこのガイドを完成しました。
Dylan Perry
メンバー登録日: 2010年01月20日
159 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 13-27, Maness Winter 2010 Cal Poly, Team 13-27, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S13G27
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 6,245
