はじめに
The CCFL Inverter is a vital part of the Apple Studio Display monitor and if it fails the monitor will have serious display problems. The CCFL inverter is what provides the backlight for the monitor. If it fails, the screen will essentially become black. This part, however, can be replaced with a new board relatively easily.
ツール
パーツ
パーツは指定されていません。
First remove the three 2mm hex screws from the top of the monitors stand.
Then, remove the four 2mm hex screws on the corners of the back panel.
Finally, the back panels can be removed by pulling the main cable through the opening and sliding the panels away.
ある他の人がこのガイドを完成しました。
