メインコンテンツにスキップ
Apple Studio Display M2454 CCFL Inverter Replacement
必要な工具と部品
  1. Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: 手順 1、 2の画像 1 Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: 手順 1、 2の画像 2
    • First remove the three 2mm hex screws from the top of the monitors stand.
    • Then, remove the four 2mm hex screws on the corners of the back panel.
    • Finally, the back panels can be removed by pulling the main cable through the opening and sliding the panels away.
  2. Apple Studio Display M2454 CCFL Inverter Replacement: 手順 2、 1の画像 1
    • Remove the metal backing.
    • Remove the single screw at the top and the two screws at the bottom of the monitor with #2 philips head screwdriver.
    • With the screws removed, push metal backing toward back of monitor to release its clips and pull away.
  3. Apple Studio Display M2454 CCFL Inverter Replacement: 手順 3、 2の画像 1 Apple Studio Display M2454 CCFL Inverter Replacement: 手順 3、 2の画像 2
    • The CCFL inverter board is the smaller of the two circuit boards with two wires and a ribbon cable running out of it.
    • Remove the two cables on the left side of the board, using a pin to insert into the two small holes and then pull out.
    • This step may be easier with two people.
    • Do not insert pin in hole with force or you risk damaging the connector.
  4. Apple Studio Display M2454 CCFL Inverter Replacement: 手順 4、 1の画像 1
    • Remove the ribbon cable on the right side of board by pulling it away from the LCD main board with hand.
  5. Apple Studio Display M2454 CCFL Inverter Replacement: 手順 5、 1の画像 1
    • Remove the top philips head screws holding the board to the monitor with #2 philips head screwdriver.
  6. Apple Studio Display M2454 CCFL Inverter Replacement: 手順 6、 1の画像 1
    • Remove the bottom philips head screw and pull the CCFL Inverter board away from monitor.
    • To replace this part with a new one, simply follow these directions in reverse using the new board.
ゴール
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Dylan Perry
メンバー登録日: 01/20/10
177 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 13-27, Maness Winter 2010 Cal Poly, Team 13-27, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S13G27
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 6,852
