メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのApple Pro Mouse (Black) M5769を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Apple Pro Mouse (Black) M5769 Teardown, Tools Needed: 手順 1、 1の画像 1
    • Step 1: The tools needed to open up an Apple Pro Mouse (Black) will be [1] Exacto Knife and [2] Spudger with one Flat end and Pointed end.
  2. Apple Pro Mouse (Black) M5769 Teardown, Opening Apple Pro Mouse: 手順 2、 3の画像 1 Apple Pro Mouse (Black) M5769 Teardown, Opening Apple Pro Mouse: 手順 2、 3の画像 2 Apple Pro Mouse (Black) M5769 Teardown, Opening Apple Pro Mouse: 手順 2、 3の画像 3
    • Step 2: Where to cut the glue points shown in RED to remove the Clear Top of the mouse.
  3. Apple Pro Mouse (Black) M5769 Teardown, Preparations Before Opening Semi-Transparent Mouse Case: 手順 3、 1の画像 1
    • Step 3: Cut the Cable Reinforcement lengthwise as shown in the picture. This will allow the reuse of this piece when you have completed the repair.
  4. Apple Pro Mouse (Black) M5769 Teardown, Opening Semi-Transparent Mouse Case: 手順 4、 1の画像 1
    • Step 3: You need to detach the Black Ring from the bottom up past midway. This will allow access to remove the Clear Mouse Tray.
  5. Apple Pro Mouse (Black) M5769 Teardown: 手順 5、 2の画像 1 Apple Pro Mouse (Black) M5769 Teardown: 手順 5、 2の画像 2
    • Step 5: Inner Clear Tray completely removed from the Semi-Transparent Black Case. Careful not to damage the cable attached to the connector on the PCB board shown in the second picture. Two cable wires were repaired by soldering them back together.
  6. Apple Pro Mouse (Black) M5769 Teardown: 手順 6、 3の画像 1 Apple Pro Mouse (Black) M5769 Teardown: 手順 6、 3の画像 2 Apple Pro Mouse (Black) M5769 Teardown: 手順 6、 3の画像 3
    • Step 6: Remove the Black Cage off the two nubs carefully. This cage covers the Red Laser and hides a clear plastic film with a rectangular white square. The white side facing the laser has a textured surface which I was unable to capture. If you lift the lower bottom edge of the PCB board you can slip it out from the Clear Tray.
  7. Apple Pro Mouse (Black) M5769 Teardown: 手順 7、 1の画像 1
    • Final Step: After reassembly this is the Apple Pro Mouse being tested showing it's Red Laser light working. Be mindful that the when reinserting the assembled Clear Tray back into the Semi-Transparent Black Case that the top lip must sit properly into a ledge/nook in the Black Case or the click will not work.
作成者
2人の作成者と共同で作成されました。
sonnyhung
メンバー登録日: 06/25/10
182 ポイント
1ガイドが承認済み
1件のガイドコメント
good not gonna lie, we need more ifixiters.
Sergei Perez - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 116
今までの合計 4,503
