メインコンテンツにスキップ
Apple Powerbook 5300 Memory Replacement
必要な工具と部品
  1. Apple Powerbook 5300 Memory Replacement, Battery: 手順 1、 1の画像 1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
  2. Apple Powerbook 5300 Memory Replacement, Keyboard: 手順 2、 1の画像 1
    • Turn the laptop over and remove the three T8 torx screws from the bottom panel.
  3. Apple Powerbook 5300 Memory Replacement: 手順 3、 1の画像 1
    • Turn the laptop back over and open the monitor.
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use a spudger to lift the white plastic retainer about 1/16" to release the cable.
  4. Apple Powerbook 5300 Memory Replacement, Memory: 手順 4、 1の画像 1
    • Pull up on the large green memory chip on the left side of the laptop. It will simply lift out.
終わりに
作成者
6人の作成者と共同で作成されました。
Scott
メンバー登録日: 04/26/11
155 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 25-30, Garner Spring 2011 Cal Poly, Team 25-30, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S25G30
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 2,392
