はじめに
This guide will show you how to install a Powerbook 5300 battery.
To begin this repair process first position the Powerbook towards you with the monitor closed, also make sure the laptop is away from anything that can cause a fire, self harm, etc.
Press the battery removal latch located on the right side of the front panel.
Gently slide the battery out. Make sure you place the battery in a safe place where it can also be easily accesible
ある他の人がこのガイドを完成しました。
