メインコンテンツにスキップ
Apple PowerBook G3 400 RAM Replacement
必要な工具と部品
  1. Apple PowerBook G3 400 RAM Replacement, Keyboard: 手順 1、 1の画像 1
    • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
  2. Apple PowerBook G3 400 RAM Replacement: 手順 2、 1の画像 1
    • Pull the keyboard ribbon vertically from the logic board to release connection.
    • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
    • Remove battery and CD/DVD drives before proceeding any further.
  3. Apple PowerBook G3 400 RAM Replacement: 手順 3、 1の画像 1
    • Your computer should look approximately like this.
  4. Apple PowerBook G3 400 RAM Replacement, RAM: 手順 4、 1の画像 1
    • Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
    • Lift the heat shield up and toward you.
  5. Apple PowerBook G3 400 RAM Replacement: 手順 5、 1の画像 1
    • Pull the PRAM battery cable vertically upward to disconnect it.
    • Remove the battery by pulling up and to the left.
  6. Apple PowerBook G3 400 RAM Replacement: 手順 6、 1の画像 1
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    • Remove the long silver Phillips #1 screw from the heat sink.
  7. Apple PowerBook G3 400 RAM Replacement: 手順 7、 1の画像 1
    • Lift up the heat sink unit from the left side and remove.
  8. Apple PowerBook G3 400 RAM Replacement: 手順 8、 1の画像 1
    • Lift the processor on the right side and pull directly up.
    • The RAM chips should be in the slots on the processor.
  9. Apple PowerBook G3 400 RAM Replacement: 手順 9、 1の画像 1
    • After removing the RAM, your laptop should now look like this.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Ian
メンバー登録日: 04/18/11
57 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 4-2, Regan Spring 2011 Cal Poly, Team 4-2, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S4G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 2,126
