1. Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
    コメントを追加する
  2. Pull the keyboard ribbon vertically from the logic board to release connection.
    • Pull the keyboard ribbon vertically from the logic board to release connection.
    • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
    • Remove battery and CD/DVD drives before proceeding any further.
    コメントを追加する
    • Your computer should look approximately like this.
    コメントを追加する
    • Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
    • Lift the heat shield up and toward you.
    コメントを追加する
    • Pull the PRAM battery cable vertically upward to disconnect it.
    • Remove the battery by pulling up and to the left.
    コメントを追加する
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    • Remove the long silver Phillips #1 screw from the heat sink.
    コメントを追加する
    • Lift up the heat sink unit from the left side and remove.
    コメントを追加する
    • Lift the processor on the right side and pull directly up.
    • The RAM chips should be in the slots on the processor.
    コメントを追加する
    • After removing the RAM, your laptop should now look like this.
    コメントを追加する
    • Locate the orange tab, which should be just left of the hard-drive.
    • You must disconnect this orange tab from the logic board to enable the next step.
    • It is better to do this by grabbing the plastic connection point, not the relatively flexible cable.
    コメントを追加する
    • Grab the plastic strip shown here and gently remove, pulling up and left.
    • Pull left to avoid the hard drive catching the casing.
    コメントを追加する
    • Once you have removed the hard-drive, your laptop should like this.
    コメントを追加する
    • Each of the Torx screws will need to be removed. They are located at each corner.
    コメントを追加する
    • Applying even pressure during this step is key. You must be careful not to damage the hard-drive beyond repair.
    • The pins are very sensitive.
    • Pull the connector cable from the hard-drive with even pressure the entire time.
    コメントを追加する
まとめ
Byron Hoefer
メンバー登録日: 2011年04月18日
70 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-2, Regan Spring 2011 Cal Poly, Team 4-2, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S4G2
4 メンバー
7のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,679
