メインコンテンツにスキップ
Apple PowerBook 520 Memory (RAM) Replacement
必要な工具と部品
  1. Apple PowerBook 520 Memory (RAM) Replacement, Case: 手順 1、 2の画像 1 Apple PowerBook 520 Memory (RAM) Replacement, Case: 手順 1、 2の画像 2
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. Apple PowerBook 520 Memory (RAM) Replacement: 手順 2、 1の画像 1
    • With monitor hinge at the bottom, remove the two top center screws.
  3. Apple PowerBook 520 Memory (RAM) Replacement: 手順 3、 1の画像 1
    • Remove top left and top right screws.
  4. Apple PowerBook 520 Memory (RAM) Replacement: 手順 4、 1の画像 1
    • Remove middle left and middle right screws.
  5. Apple PowerBook 520 Memory (RAM) Replacement: 手順 5、 1の画像 1
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
  6. Apple PowerBook 520 Memory (RAM) Replacement: 手順 6、 1の画像 1
    • Lift keyboard from bottom and take out of shell.
  7. Apple PowerBook 520 Memory (RAM) Replacement: 手順 7、 3の画像 1 Apple PowerBook 520 Memory (RAM) Replacement: 手順 7、 3の画像 2 Apple PowerBook 520 Memory (RAM) Replacement: 手順 7、 3の画像 3
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
  8. Apple PowerBook 520 Memory (RAM) Replacement, Memory (RAM): 手順 8、 1の画像 1
    • Open the panel on back of the device. Remove 2 T8 torque screws.
  9. Apple PowerBook 520 Memory (RAM) Replacement: 手順 9、 1の画像 1
    • Remove the plastic panel underneath the LCD Screen.
  10. Apple PowerBook 520 Memory (RAM) Replacement: 手順 10、 1の画像 1
    • Remove the 2 T8 Torx Screws securing the logic board protection plate from the midsection of the logic board protection plate. Remove the T8 Torx Screw from the back of the plate, underneath the hinge.
  11. Apple PowerBook 520 Memory (RAM) Replacement: 手順 11、 1の画像 1
    • Remove the logic board protection plate.
  12. Apple PowerBook 520 Memory (RAM) Replacement: 手順 12、 1の画像 1
    • Using a plastic spudger, gently pry up the uppermost board fixture. This is the Memory (RAM).
  13. Apple PowerBook 520 Memory (RAM) Replacement: 手順 13、 1の画像 1
    • Once the old Memory board is removed, replace it with the new Memory board.
終わりに
2 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Tyler
メンバー登録日: 04/10/11
142 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 20-66, Walters Spring 2011 Cal Poly, Team 20-66, Walters Spring 2011人のメンバー
CPSU-WALTERS-S11S20G66
4 メンバー
3のガイドは作成済み
コメント 1 件
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 48
今までの合計 3,350
