メインコンテンツにスキップ
Apple Magic Keyboard 2 A2450 Keyboard Replacement
必要な工具と部品
  1. Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: 手順 1、 3の画像 1 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: 手順 1、 3の画像 2 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: 手順 1、 3の画像 3
    • Apply heat around the perimeter of the lower case to loosen the adhesive that secures the lower case to the chassis.
    • The plastic should be a bit too warm to touch comfortably, but not hot.
    • Insert an opening pick in the gap between the lower case and chassis.
    • After ensuring that the adhesive is warm, slide the pick around the perimeter to sever the adhesive.
    • As you sever the adhesive, insert additional opening picks at each corner to prevent the adhesive from readhering.
    • Remove the lower case.
  2. Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: 手順 2、 3の画像 1 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: 手順 2、 3の画像 2 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: 手順 2、 3の画像 3
    • Use a T3 Torx screwdriver head to remove all twelve 5 mm that secure the midframe.
    • Use tweezers to disconnect the battery motherboard connection.
    • Remove the midframe.
  3. Apple Magic Keyboard 2 A2450 Keyboard Replacement: 手順 3、 3の画像 1 Apple Magic Keyboard 2 A2450 Keyboard Replacement: 手順 3、 3の画像 2 Apple Magic Keyboard 2 A2450 Keyboard Replacement: 手順 3、 3の画像 3
    • Use a T3 Torx screwdriver to remove the two 5 mm screws that secure the lightning port.
    • Use tweezers to remove the Lighting port from the motherboard.
  4. Apple Magic Keyboard 2 A2450 Keyboard Replacement: 手順 4、 3の画像 1 Apple Magic Keyboard 2 A2450 Keyboard Replacement: 手順 4、 3の画像 2 Apple Magic Keyboard 2 A2450 Keyboard Replacement: 手順 4、 3の画像 3
    • Use a T3 Torx screwdriver to remove the three 3 mm screws that secure the motherboard.
    • Remove the tape covering the ribbon cable on the top half of the motherboard.
    • Use a small pair of tweezers to gently unplug the ribbon cable and remove the motherboard from the keyboard.
  5. Apple Magic Keyboard 2 A2450 Keyboard Replacement: 手順 5、 3の画像 1 Apple Magic Keyboard 2 A2450 Keyboard Replacement: 手順 5、 3の画像 2 Apple Magic Keyboard 2 A2450 Keyboard Replacement: 手順 5、 3の画像 3
    • Use a T3 Torx screwdriver to remove the single 3 mm screw that secures the assembly to the frame.
    • Use tweezers to unplug the power switch from the case. Pull horizontally on the entire assembly to remove the switch from the keyboard.
  6. Apple Magic Keyboard 2 A2450 Keyboard Replacement: 手順 6、 1の画像 1
    • Replace the keyboard.
終わりに
作成者
3人の作成者と共同で作成されました。
Alex
メンバー登録日: 04/02/24
219 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 3-2, Harley Spring 2024 IUPUI, Team 3-2, Harley Spring 2024人のメンバー
IUPUI-HARLEY-S24S3G2
4 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 29
過去 30 日: 157
今までの合計 2,125
