メインコンテンツにスキップ
Apple Lisa MacWorks II PFG Instalation
必要な工具と部品
  1. Apple Lisa MacWorks II PFG Instalation, Disassembly: 手順 1、 2の画像 1 Apple Lisa MacWorks II PFG Instalation, Disassembly: 手順 1、 2の画像 2
  2. Apple Lisa MacWorks II PFG Instalation, Remove I/O Board: 手順 2、 2の画像 1 Apple Lisa MacWorks II PFG Instalation, Remove I/O Board: 手順 2、 2の画像 2
    • Remove the Lisa's I/O Board. The I/O Board's clips are marked in red.
    • Release both clips holding the I/O Board.
    • Pull the I/O Board up to remove it.
  3. Apple Lisa MacWorks II PFG Instalation, Removing the 8530 Chip: 手順 3、 1の画像 1
    • Remove the chip marked 8530 at location 9D.
  4. Apple Lisa MacWorks II PFG Instalation, Crystal Insulation: 手順 4、 1の画像 1
    • Next to the chip removed in step 3 is a crystal. These are not always installed with a plastic coating. The crystal shown in the image is insulated.
    • If your crystal is not insulated then tape a small piece of cardboard on top of it.
  5. Apple Lisa MacWorks II PFG Instalation, Installing the Daughter Board: 手順 5、 1の画像 1
    • Ensure the pins on the MW+II PFG (Programable Frequency Generator) are perfectly straight. If they are not then slightly bend them into place.
    • Insert the PFG into the 8530 socket.
  6. Apple Lisa MacWorks II PFG Instalation, Attaching Red and Black Wires: 手順 6、 3の画像 1 Apple Lisa MacWorks II PFG Instalation, Attaching Red and Black Wires: 手順 6、 3の画像 2 Apple Lisa MacWorks II PFG Instalation, Attaching Red and Black Wires: 手順 6、 3の画像 3
    • Locate the chip marked LS132 located at 6A.
    • Connect the Red and Black wires as shown in the second image on this step.
    • It is best to place a piece of electrical tape on the wires to help hold them in place.
  7. Apple Lisa MacWorks II PFG Instalation: 手順 7、 1の画像 1
    • Replace the I/O Board back into Lisa's Card Cage.
    • Replace Lisa's Card Cage Back into the Lisa.
    • Replace the rear panel on the Lisa.
    • MacWorks + II (MW+II) floppy images can be found here.
    • The MW+II manual can be found here which includes detailed instructions how to instal thel MW+II software.
終わりに
  • MW+II supports Macintosh System Software up to Macintosh System 7.5.5.
  • Supports over 10MB of RAM (more than 4MB requires an XLerator.)
ある他の人がこのガイドを完成しました。
添付文書
作成者
1人の作成者と共同作成されました。
LisaGuide
メンバー登録日: 12/30/18
1,833 ポイント
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 19
今までの合計 595
