はじめに
This guide will help you re-seat or replace the IC chips on the computer's mother board. The IC chips, or Integrated Circuit chips, are used to perform various vital functions on the computer. Chips coming unseated or going bad is a common problem with the Apple II series and is easily fixed or replaced. Re-seating your chips will helpful if you are having trouble running your computer.
必要な工具と部品
Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
Use the plastic opening tools to carefully lever the IC chips out of the holder. Gently lever one end and then the other to lift it out of the chip holder.
9 の人々がこのガイドを完成させました。
1件のガイドコメント
What are the 4 round black things shown in the photos in Step 1 and Step 6? (No explanation is given.)
