メインコンテンツにスキップ
Apple IIc Floppy Drive Replacement
必要な工具と部品
  1. Apple IIc Floppy Drive Replacement, Disassembling Apple IIc Cover: 手順 1、 2の画像 1 Apple IIc Floppy Drive Replacement, Disassembling Apple IIc Cover: 手順 1、 2の画像 2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Apple IIc Floppy Drive Replacement: 手順 2、 2の画像 1 Apple IIc Floppy Drive Replacement: 手順 2、 2の画像 2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Apple IIc Floppy Drive Replacement: 手順 3、 2の画像 1 Apple IIc Floppy Drive Replacement: 手順 3、 2の画像 2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Apple IIc Floppy Drive Replacement: 手順 4、 2の画像 1 Apple IIc Floppy Drive Replacement: 手順 4、 2の画像 2
    • Lift the handle straight up to remove.
  5. Apple IIc Floppy Drive Replacement, Keyboard: 手順 5、 2の画像 1 Apple IIc Floppy Drive Replacement, Keyboard: 手順 5、 2の画像 2
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
  6. Apple IIc Floppy Drive Replacement, Floppy Drive: 手順 6、 2の画像 1 Apple IIc Floppy Drive Replacement, Floppy Drive: 手順 6、 2の画像 2
    • Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
  7. Apple IIc Floppy Drive Replacement: 手順 7、 3の画像 1 Apple IIc Floppy Drive Replacement: 手順 7、 3の画像 2 Apple IIc Floppy Drive Replacement: 手順 7、 3の画像 3
    • Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally.
  8. Apple IIc Floppy Drive Replacement: 手順 8、 2の画像 1 Apple IIc Floppy Drive Replacement: 手順 8、 2の画像 2
    • Unscrew the four 8.5 mm screws that attach the floppy drive cage. Two screws are located on the front and back of the cage.
  9. Apple IIc Floppy Drive Replacement: 手順 9、 2の画像 1 Apple IIc Floppy Drive Replacement: 手順 9、 2の画像 2
    • Carefully lift the floppy drive cage straight up to remove it.
  10. Apple IIc Floppy Drive Replacement: 手順 10、 2の画像 1 Apple IIc Floppy Drive Replacement: 手順 10、 2の画像 2
    • Lift the floppy drive straight up to remove.
終わりに
8 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Alexandria Weinberg
メンバー登録日: 10/06/11
601 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 21-23, Maness Fall 2011 Cal Poly, Team 21-23, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S21G23
4 メンバー
13のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 24
今までの合計 5,914
