ビデオインストラクション
終わりに
過去 24時間: 2
過去 7 日: 21
過去 30 日: 94
今までの合計 7,219
3件のガイドコメント
Not helpful if one is trying to remove a key for cleaning, without damaging anything.
Moeskido - 返信
yeah, do you know how to remove the keys?
Jaide s -
insert a thin screwdriver under the lower edge and pry up gently until it snaps out of the retainer clip, then pry up gently on the upper edge.
You may be able to dislodge any small debris under the keys without fully removing the key if you just pry the bottom loose and blow underneath.
Rich Wiebe - 返信
