メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのApple EarPodsを修理する際は、iFixitの修理ガイドをご利用ください。
    • Using a sharp utility knife, score the plastic casing all around. Locate the cut at about half of the casing’s length length.
    • Important: Take extreme care with your fingers due to the small size of the casing, the smooth and slippery surface of the casing, and how close your fingers will be to the blade when doing this.
    • Make the score lines as perpendicular to the casing as possible, and make them meet at a point after going around the casing. This will make the next step a lot easier. Marking out the score line with a permanent pen before scoring would help.
    • Continue scoring along the lines made (very carefully as per the first step), and gradually apply more pressure as the cuts become deeper.
    • Reduce pressure as you sense that you are getting close to cutting through the plastic.
    • As you just break through the plastic on the flat side (not on either of the round sides), you will feel the blade start to scrape on metal. At this point, start to gently slice around the cut / score line all the way around the casing, avoiding cutting into the metal as much as possible.
  1. Apple EarPods Lightning Connector Teardown, Remove casing: 手順 3、 1の画像 1
    • Once the casing has been split/cut apart, you should be able to pull off the section on the connector side.
    • The white rubber seal/gasket will probably come off, but this can be quite easily pushed back into place if needed.
    • The section of casing on the cable side is harder to remove. Use the tip of the utility knife, or better still, a scalpel, to cut and pry it away from the main body.
    • As you can see, there are no exposed cables or terminals to fix or re-solder. Maybe this guide saved you the time of actually taking it apart, or maybe you’d like to attempt to open up the metal housing inside and do some micro-surgery. Hope this helped in any case.
作成者
1人の作成者と共同作成されました。
E Text
メンバー登録日: 08/21/19
129 ポイント
1ガイドが承認済み
コメント 1 件
Lol, Hard but fair!!!
Laconia Hughes - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 34
今までの合計 3,929
