はじめに
Use this guide to help you optimize audio function from your Apple EarPods.
必要な工具と部品
Using a triangle paddle, apply sufficient pressure to get in-between the opening section
Soak one side of a cotton swab with alcohol
Clean inner and outer pod using swab soaked in alcohol
Carefully clean the speaker cone using cotton swab
Once clean, reattach the earbud
Carefully remove grill out of both earbuds using tweezers
Take precautions not to bend grill excessively
Clean grill with cotton swab soaked in alcohol
Remove any build up of wax or sweat
To reassemble your device, follow Step 7, Step 4 and Step 2 instructions in reverse order.
7 の人々がこのガイドを完成させました。
コメント 1 件
When I re assemble they won’t stay closed. Do I glue them back together?
