メインコンテンツにスキップ
Apple Cinema Display M8149 Voltage Inverter Replacement
必要な工具と部品
  1. Apple Cinema Display M8149 Voltage Inverter Replacement, Control Boards: 手順 1、 3の画像 1 Apple Cinema Display M8149 Voltage Inverter Replacement, Control Boards: 手順 1、 3の画像 2 Apple Cinema Display M8149 Voltage Inverter Replacement, Control Boards: 手順 1、 3の画像 3
    • Before starting, make sure the display is unplugged.
    • Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
    • Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
    • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
  2. Apple Cinema Display M8149 Voltage Inverter Replacement: 手順 2、 3の画像 1 Apple Cinema Display M8149 Voltage Inverter Replacement: 手順 2、 3の画像 2 Apple Cinema Display M8149 Voltage Inverter Replacement: 手順 2、 3の画像 3
    • Remove the eighteen (5.25 x 4.43 mm) screws around the edge of the backplate using the Hex key.
    • Disconnect the small white connector leading to the display's Power button.
    • Gently lift the backplate off of the display. Completely remove the backplate and set it aside.
  3. Apple Cinema Display M8149 Voltage Inverter Replacement: 手順 3、 2の画像 1 Apple Cinema Display M8149 Voltage Inverter Replacement: 手順 3、 2の画像 2
    • Use a Phillips #2 screwdriver to remove the four (9.52 x 3.43 mm) screws on the outer rim of the metal cover.
    • Next, remove the four cover (11.91 x 2.89 mm) screws located at the corners of the metal cover using the Phillips #2 screwdriver.
  4. Apple Cinema Display M8149 Voltage Inverter Replacement: 手順 4、 3の画像 1 Apple Cinema Display M8149 Voltage Inverter Replacement: 手順 4、 3の画像 2 Apple Cinema Display M8149 Voltage Inverter Replacement: 手順 4、 3の画像 3
    • Unplug the large brown plug in the center-right, that connects the control board to the rest of the display.
    • Unplug the blue and gray plug on the right side of the control board. Repeat with the left side.
  5. Apple Cinema Display M8149 Voltage Inverter Replacement: 手順 5、 2の画像 1 Apple Cinema Display M8149 Voltage Inverter Replacement: 手順 5、 2の画像 2
    • Gently lift the large metal cover which spans across the back of the whole display.
  6. Apple Cinema Display M8149 Voltage Inverter Replacement, Voltage Inverter: 手順 6、 3の画像 1 Apple Cinema Display M8149 Voltage Inverter Replacement, Voltage Inverter: 手順 6、 3の画像 2 Apple Cinema Display M8149 Voltage Inverter Replacement, Voltage Inverter: 手順 6、 3の画像 3
    • Turn your attention to the left side of the cinema display.
    • Using your fingers, unplug the small white plugs with pink wires from the top and bottom of the circuit board.
    • Using the PH 2 screw driver, remove the four screws (6.9 x 2.55 mm) holding down the circuit board.
    • Remove the circuit board by gently lifting it from the display.
終わりに
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Brett Murphy
メンバー登録日: 04/01/11
197 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 10-41, Forte Spring 2011 Cal Poly, Team 10-41, Forte Spring 2011人のメンバー
CPSU-FORTE-S11S10G41
5 メンバー
12のガイドは作成済み
コメント 1 件
Brilliantly clear and simple to follow. As I suspected it was the inverter board that failed leaving me a totally black screen on my 20 year old 22 inch Cinema display (ADC). Your guide enabled me to restore the monitor to working order, and it’s now paired once again with my Apple cube. Thank you ever so much!
kevin.raddy - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 17
今までの合計 4,940
