メインコンテンツにスキップ
Apple Cinema Display M8149 LCD Screen Replacement
必要な工具と部品
  1. Apple Cinema Display M8149 LCD Screen Replacement, Control Boards: 手順 1、 3の画像 1 Apple Cinema Display M8149 LCD Screen Replacement, Control Boards: 手順 1、 3の画像 2 Apple Cinema Display M8149 LCD Screen Replacement, Control Boards: 手順 1、 3の画像 3
    • Before starting, make sure the display is unplugged.
    • Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
    • Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
    • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
  2. Apple Cinema Display M8149 LCD Screen Replacement: 手順 2、 3の画像 1 Apple Cinema Display M8149 LCD Screen Replacement: 手順 2、 3の画像 2 Apple Cinema Display M8149 LCD Screen Replacement: 手順 2、 3の画像 3
    • Remove the eighteen (5.25 x 4.43 mm) screws around the edge of the backplate using the Hex key.
    • Disconnect the small white connector leading to the display's Power button.
    • Gently lift the backplate off of the display. Completely remove the backplate and set it aside.
  3. Apple Cinema Display M8149 LCD Screen Replacement: 手順 3、 2の画像 1 Apple Cinema Display M8149 LCD Screen Replacement: 手順 3、 2の画像 2
    • Use a Phillips #2 screwdriver to remove the four (9.52 x 3.43 mm) screws on the outer rim of the metal cover.
    • Next, remove the four cover (11.91 x 2.89 mm) screws located at the corners of the metal cover using the Phillips #2 screwdriver.
  4. Apple Cinema Display M8149 LCD Screen Replacement: 手順 4、 3の画像 1 Apple Cinema Display M8149 LCD Screen Replacement: 手順 4、 3の画像 2 Apple Cinema Display M8149 LCD Screen Replacement: 手順 4、 3の画像 3
    • Unplug the large brown plug in the center-right, that connects the control board to the rest of the display.
    • Unplug the blue and gray plug on the right side of the control board. Repeat with the left side.
  5. Apple Cinema Display M8149 LCD Screen Replacement: 手順 5、 2の画像 1 Apple Cinema Display M8149 LCD Screen Replacement: 手順 5、 2の画像 2
    • Gently lift the large metal cover which spans across the back of the whole display.
  6. Apple Cinema Display M8149 LCD Screen Replacement, LCD Control Board: 手順 6、 3の画像 1 Apple Cinema Display M8149 LCD Screen Replacement, LCD Control Board: 手順 6、 3の画像 2 Apple Cinema Display M8149 LCD Screen Replacement, LCD Control Board: 手順 6、 3の画像 3
    • Carefully remove the two tape plugs on either side of the control board using a spudger.
  7. Apple Cinema Display M8149 LCD Screen Replacement: 手順 7、 3の画像 1 Apple Cinema Display M8149 LCD Screen Replacement: 手順 7、 3の画像 2 Apple Cinema Display M8149 LCD Screen Replacement: 手順 7、 3の画像 3
    • Pull the previously removed tape out from the metal box with your hand.
    • Peel back the white plastic cover located on the tape plug and unplug the tape plug on the right side of the unit using the spudger.
  8. Apple Cinema Display M8149 LCD Screen Replacement: 手順 8、 3の画像 1 Apple Cinema Display M8149 LCD Screen Replacement: 手順 8、 3の画像 2 Apple Cinema Display M8149 LCD Screen Replacement: 手順 8、 3の画像 3
    • Unscrew the four screws (4.79x2.33mm) on the metal box using the Phillips #2 screwdriver.
    • Lift the metal cover off to reveal a circuit board.
    • Remove the two terminal screws (4.79x2.34mm) using the Phillips #2 screwdriver.
  9. Apple Cinema Display M8149 LCD Screen Replacement: 手順 9、 2の画像 1 Apple Cinema Display M8149 LCD Screen Replacement: 手順 9、 2の画像 2
    • Remove the terminal cover.
    • Remove the circuit board from the right side of the unit by gently lifting it out.
  10. Apple Cinema Display M8149 LCD Screen Replacement, Voltage Inverter: 手順 10、 3の画像 1 Apple Cinema Display M8149 LCD Screen Replacement, Voltage Inverter: 手順 10、 3の画像 2 Apple Cinema Display M8149 LCD Screen Replacement, Voltage Inverter: 手順 10、 3の画像 3
    • Turn your attention to the left side of the cinema display.
    • Using your fingers, unplug the small white plugs with pink wires from the top and bottom of the circuit board.
    • Using the PH 2 screw driver, remove the four screws (6.9 x 2.55 mm) holding down the circuit board.
    • Remove the circuit board by gently lifting it from the display.
  11. Apple Cinema Display M8149 LCD Screen Replacement, LCD Screen: 手順 11、 3の画像 1 Apple Cinema Display M8149 LCD Screen Replacement, LCD Screen: 手順 11、 3の画像 2 Apple Cinema Display M8149 LCD Screen Replacement, LCD Screen: 手順 11、 3の画像 3
    • Lift the screen from the surrounding front cover by sliding your fingers between the two pieces and lifting.
終わりに
3 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Curtis Musashi
メンバー登録日: 04/01/11
152 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-41, Forte Spring 2011 Cal Poly, Team 10-41, Forte Spring 2011人のメンバー
CPSU-FORTE-S11S10G41
5 メンバー
12のガイドは作成済み
2件のガイドコメント
hello! where can i buy lcd screen for m8149?
jgill1971 - 返信
Does anyone know where to get an inexpensive LCD replacement. Mine went primarily magneta except for the outer edges after zapping the pram?! Totally bummed as I bought a DVI to ADC power source and now the monitor is useless in it’s current state. C’est la vie!
le_grand - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 8,651
