はじめに
Apple Cinema Display M8149 LCD Control Board Replacement Guide: This guide will show you the steps on how to gain access to the control board on an Apple Cinema Display. Due to the age of the device I would be very careful with the internals and stray parts. The goal here is to switch out the main circuit because with time the old apple products will wear down.
必要な工具と部品
Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
Carefully remove the two tape plugs on either side of the control board using a spudger.
ある他の人がこのガイドを完成しました。
