メインコンテンツにスキップ
Apple Airport Extreme Model A1408 WiFi Card Replacement
必要な工具と部品
  1. Apple Airport Extreme Model A1408 WiFi Card Replacement, Back Pad: 手順 1、 1の画像 1
    • CAUTION: The heat gun and hair dryer can get very hot. Do not put your hands or any other body part too close to either device. Also, do not touch the back pad right after heating it.
    • Use a blow dryer or heat gun on a medium to high heat setting on the back pad to loosen the glue that attaches it to the device.
  2. Apple Airport Extreme Model A1408 WiFi Card Replacement: 手順 2、 1の画像 1
    • To avoid ripping the back pad, gently peel it back from one corner until the pad is completely off.
    • Use heat in areas where the glue is not loose enough.
    • You may need to reattach the back pad with double-sided tape if the glue is not tacky enough to stick the pad back on.
  3. Apple Airport Extreme Model A1408 WiFi Card Replacement, Outer Case: 手順 3、 2の画像 1 Apple Airport Extreme Model A1408 WiFi Card Replacement, Outer Case: 手順 3、 2の画像 2
    • After removing the back pad, unscrew the five 5 mm Phillips #00 screws in the large, deep holes in the plastic casing. The plastic casing should come off easily after removing all the screws.
    • When installing the plastic back cover, ensure the lip is aligned with the ports on the back of the device.
  4. Apple Airport Extreme Model A1408 WiFi Card Replacement: 手順 4、 2の画像 1 Apple Airport Extreme Model A1408 WiFi Card Replacement: 手順 4、 2の画像 2
    • Insert a narrow plastic opening tool into one of the notches. Apply moderate force to pull the metal casing from the plastic outer casing. You can use the rim of the outer case as leverage. You should hear a click when the metal casing detaches.
    • After you hear the click, remove the inner metal case from the outer case using your hands. It should not take very much force.
  5. Apple Airport Extreme Model A1408 WiFi Card Replacement, WiFi Card: 手順 5、 2の画像 1 Apple Airport Extreme Model A1408 WiFi Card Replacement, WiFi Card: 手順 5、 2の画像 2
    • Remove the four wires coming from the antennas by pinching the cable at the tip and gently pulling up on it until it pops out of the socket.
    • Repeat for the remaining three wires.
    • You might need to wiggle the wire to free it from the socket.
  6. Apple Airport Extreme Model A1408 WiFi Card Replacement: 手順 6、 1の画像 1
    • Remove the 5 mm Phillips #00 screw from the right side of the WiFi card.
  7. Apple Airport Extreme Model A1408 WiFi Card Replacement: 手順 7、 2の画像 1 Apple Airport Extreme Model A1408 WiFi Card Replacement: 手順 7、 2の画像 2
    • Do not pull the WiFi card directly up or you may damage the slot and the logic board.
    • Remove the WiFi card by gripping it on both sides and gently pulling it directly out of the slot.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ryan Frawley
メンバー登録日: 10/14/14
379 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 10-37, Amido Fall 2014 Cal Poly, Team 10-37, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S10G37
4 メンバー
12のガイドは作成済み
コメント 1 件
Hi. By what wifi card can I replace the old one?
Robin Geerdens - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 23
今までの合計 2,856
