メインコンテンツにスキップ
Apple AirPort Extreme Model A1354 Logic Board Replacement
必要な工具と部品
  1. Apple AirPort Extreme Model A1354 Logic Board Replacement, Outer Case: 手順 1、 1の画像 1
    • First start by peeling off the outer rubbery covering on the bottom of the device.
    • CAUTION: This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
  2. Apple AirPort Extreme Model A1354 Logic Board Replacement: 手順 2、 1の画像 1
    • After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
  3. Apple AirPort Extreme Model A1354 Logic Board Replacement: 手順 3、 1の画像 1
    • After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
  4. Apple AirPort Extreme Model A1354 Logic Board Replacement: 手順 4、 3の画像 1 Apple AirPort Extreme Model A1354 Logic Board Replacement: 手順 4、 3の画像 2 Apple AirPort Extreme Model A1354 Logic Board Replacement: 手順 4、 3の画像 3
    • The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
    • It should make a click when it comes apart.
  5. Apple AirPort Extreme Model A1354 Logic Board Replacement: 手順 5、 1の画像 1
    • Remove the outer casing.
    • The exposed logic board should look like this.
  6. Apple AirPort Extreme Model A1354 Logic Board Replacement, WiFi Card: 手順 6、 1の画像 1
    • Take the device out of the casing and orient it so that you can see the WiFi card.
  7. Apple AirPort Extreme Model A1354 Logic Board Replacement: 手順 7、 1の画像 1
    • Wires come from the three antennas and connect on the outer edge of the WiFi card.
    • Carefully pull up on the end of one of the wires to disconnect it from the motherboard.
    • Do this for the remaining two wires.
  8. Apple AirPort Extreme Model A1354 Logic Board Replacement: 手順 8、 1の画像 1
    • There are two clips attached to the upper and lower ends of the WiFi card
    • CAUTION: For the following step, do not pull the clip after you have detached it. The clip is fragile and too much force may cause the clip to break.
    • Grab the end of one of the clips and pull away from the WiFi card. This should make the clip visibly detached from the WiFi card.
    • Do the same for the other clip.
  9. Apple AirPort Extreme Model A1354 Logic Board Replacement: 手順 9、 2の画像 1 Apple AirPort Extreme Model A1354 Logic Board Replacement: 手順 9、 2の画像 2
    • Grasp the upper and lower ends of the WiFi card.
    • Carefully pull the WiFi card to the right.
    • CAUTION: Do not pull UP (towards yourself) on the WiFi card when removing. The card is on a track that only allows it to move left and right. Forcing the card to move in other directions may result in breaking the track.
    • Completely remove the WiFi card.
  10. Apple AirPort Extreme Model A1354 Logic Board Replacement, Battery: 手順 10、 1の画像 1
    • Remove the metal casing by gently prying the logic board away with you hands.
    • This should be pretty easy, you already removed the screws holding these pieces together.
  11. Apple AirPort Extreme Model A1354 Logic Board Replacement: 手順 11、 3の画像 1 Apple AirPort Extreme Model A1354 Logic Board Replacement: 手順 11、 3の画像 2 Apple AirPort Extreme Model A1354 Logic Board Replacement: 手順 11、 3の画像 3
    • Remove the battery by gently "shoving" it out with the plastic tool.
  12. Apple AirPort Extreme Model A1354 Logic Board Replacement, Logic Board: 手順 12、 1の画像 1
    • This is the "naked" logic board. You can order a new one and replace it by following the above steps in reverse order.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Brandon
メンバー登録日: 04/02/12
387 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 5-2, Forte Spring 2012 Cal Poly, Team 5-2, Forte Spring 2012人のメンバー
CPSU-FORTE-S12S5G2
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 33
今までの合計 8,871
