はじめに
If the base station does not turn on, the battery may need to be replaced.
必要な工具と部品
First start by peeling off the outer rubbery covering on the bottom of the device.
Remove the metal casing by gently prying the logic board away with you hands.
This should be pretty easy, you already removed the screws holding these pieces together.
7 の人々がこのガイドを完成させました。
5 件のコメント
Hi! How to know i need to change battery? What the symptoms of dead battery? My Airport Extreme worked well 6 years, and now its have the problems, missing pings, can it be symptom of dead battery?
stormmouse - 返信
