この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If the base station is sending out a poor signal, an antenna may need to be replaced.
必要な工具と部品
First start by peeling off the outer rubbery covering on the bottom of the device.
Remove the metal casing by gently prying the logic board away with you hands.
This should be pretty easy, you already removed the screws holding these pieces together.
4 の人々がこのガイドを完成させました。
