メインコンテンツにスキップ
Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement
必要な工具と部品
  1. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Back Pad: 手順 1、 1の画像 1
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
  2. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Back Cover: 手順 2、 1の画像 1
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  3. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement: 手順 3、 1の画像 1
    • Lift up the back case from the perforated edge to remove it.
  4. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Remove from Case: 手順 4、 1の画像 1
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
  5. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Detach Logic Board From Case: 手順 5、 1の画像 1
    • Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
  6. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Pull Back Tabs: 手順 6、 1の画像 1
    • Carefully push back the three metal tabs with your fingers on the sides of metal case.
  7. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Remove Metal case: 手順 7、 1の画像 1
    • Carefully pull the metal case away from the logic board.
  8. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Wi-Fi Antenna: 手順 8、 1の画像 1
    • Unscrew the 5mm #00 screws from each of the three antennas located on the sides of the metal casing.
    • Pull away antennas from metal case.
  9. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement: 手順 9、 2の画像 1 Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement: 手順 9、 2の画像 2
    • Pull up the less visible silver tape that holds the antenna cords in place at the ends of the device using your fingers.
    • Remove clear yellow tape that holds the cords to the outer casing in the same manner.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Dillon Huffsmith
メンバー登録日: 09/23/14
295 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 12-4, Blackwell Fall 2014 USF Tampa, Team 12-4, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S12G4
5 メンバー
10のガイドは作成済み
2 件のコメント
Thanks for the guide.
Pulled mine apart to examine the battery inside. It measured above 3.1 volts - even though it has been in use since June 2008 (about 9 years).
Holes will be punched for access to the 5 screws so the rubber pad does not have to be removed if it needs to be opened in the future.
I may see about buying a new Ac adapter to power this Airport Extreme since that is probably why the status light on the front did not illuminate.
doctordon - 返信
Completed this. Didnt use apple replacement antennas. Added 3 U.FL Mini PCI to RP-SMA Pigtails, drilled 3 holes and mounted 3 +9db antennas. My wifi finally reaches my garage
David Bunting - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,774
