メインコンテンツにスキップ
Apple AirPort Extreme Model A1143 Logic Board Replacement
必要な工具と部品
  1. Apple AirPort Extreme Model A1143 Logic Board Replacement, Back Pad: 手順 1、 1の画像 1
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
    This is where you would use the opening tool. It’s the perfect tool to lift the rubber base around the metal lip and then pull with your fingers.
    Eddie de la Rosa - 返信
  2. Apple AirPort Extreme Model A1143 Logic Board Replacement, Back Cover: 手順 2、 1の画像 1
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  3. Apple AirPort Extreme Model A1143 Logic Board Replacement: 手順 3、 1の画像 1
    • Lift up the back case from the perforated edge to remove it.
  4. Apple AirPort Extreme Model A1143 Logic Board Replacement, Remove from Case: 手順 4、 1の画像 1
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
    I have found it easier to lift from the side with the Ethernet ports. When putting back together watch that the three WI-FI antennas don’t get snagged against the case as your putting back.
    Take care to remove the small pieces of metallic tape between the case and the spring copper comb earthing strips in the case.
    If you do not, it is a real fiddle to put them back in place latter (the tape will pull them out of the case ground steps)
    Robert.
    PS: I believe the onboard power converter is bust: the board sings when power turned on. So to trash it goes.
    (external power supply is good), swapped with another to test).
    Sad…
    Robert McInnes - 返信
  5. Apple AirPort Extreme Model A1143 Logic Board Replacement, Detach Logic Board From Case: 手順 5、 1の画像 1
    • Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
  6. Apple AirPort Extreme Model A1143 Logic Board Replacement, Pull Back Tabs: 手順 6、 1の画像 1
    • Carefully push back the three metal tabs with your fingers on the sides of metal case.
  7. Apple AirPort Extreme Model A1143 Logic Board Replacement, Remove Metal case: 手順 7、 1の画像 1
    • Carefully pull the metal case away from the logic board.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Zak
メンバー登録日: 09/23/14
616 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 12-4, Blackwell Fall 2014 USF Tampa, Team 12-4, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S12G4
5 メンバー
10のガイドは作成済み
コメント 1 件
my apple a1143 wont turn on at all no light.
what can it be done?
Gabriel barradenguy - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 2,510
