はじめに
This will be the starting point for any repairs that you may need to do on your Apple AirPort Extreme Model A1143. Some patience should be used when removing the case as it can be fragile.
パーツ
パーツは指定されていません。
Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
Remove logic board and metal casing from outer case by prying from one side using a spudger.
6 の人々がこのガイドを完成させました。
