メインコンテンツにスキップ
Apex Digital DTV Converter Box Power supply Board replacement
必要な工具と部品
  1. Apex Digital DTV Converter Box Power supply Board replacement, Power Board: 手順 1、 1の画像 1
    • Unplug your device from the wall outlet.
  2. Apex Digital DTV Converter Box Power supply Board replacement: 手順 2、 1の画像 1
    • Remove the screws on the sides and rear. There are two on each side and four on the back.
    • Note: only remove the black ones (the silver ones stay for now). You should have removed eight identical screws by now.
  3. Apex Digital DTV Converter Box Power supply Board replacement: 手順 3、 1の画像 1
    • Lift the top cover up and toward you simultaneously. It shouldn't require very much force.
  4. Apex Digital DTV Converter Box Power supply Board replacement: 手順 4、 1の画像 1
    • Locate the power board inside the converter box.
    • Circled in red in the picture.
  5. Apex Digital DTV Converter Box Power supply Board replacement: 手順 5、 1の画像 1
    • Remove this plug
    • You will need to squeeze the locking lever to release it. don't pull too hard.
  6. Apex Digital DTV Converter Box Power supply Board replacement: 手順 6、 1の画像 1
    • Remove this plug from the main board. It is not detachable from the power board end.
    • Be gentle.
  7. Apex Digital DTV Converter Box Power supply Board replacement: 手順 7、 1の画像 1
    • Remove one last cable. This one leads to the front panel
    • Be gentle.
    • Circled in red
  8. Apex Digital DTV Converter Box Power supply Board replacement: 手順 8、 1の画像 1
    • Remove the power cord from its slot in the casing. This will make it easier to remove the power board.
    • Circled in blue
  9. Apex Digital DTV Converter Box Power supply Board replacement: 手順 9、 1の画像 1
    • Remove the four silver colored philips screws holding the power board in.
    • Marked in pink (eeww)
  10. Apex Digital DTV Converter Box Power supply Board replacement: 手順 10、 1の画像 1
    • Lift the power board out. Be careful to not touch the bottom of the power board. even when unplugged, it may still hold a charge.
    • Here is the empty spot.
終わりに
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Michel
メンバー登録日: 06/18/10
288 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 9,002
