メインコンテンツにスキップ
Anker 2.4G Wireless Mouse Side Button Replacement
必要な工具と部品
  1. Anker 2.4G Wireless Mouse Side Button Replacement, Side Button: 手順 1、 1の画像 1
    • Flip the mouse over so that the bottom is facing up.
    • Using a prying tool to peel off the black stickers from the bottom of the mouse.
  2. Anker 2.4G Wireless Mouse Side Button Replacement: 手順 2、 1の画像 1
    • Using the Phillips #0 screwdriver, remove the four screws from the bottom of the mouse.
  3. Anker 2.4G Wireless Mouse Side Button Replacement: 手順 3、 3の画像 1 Anker 2.4G Wireless Mouse Side Button Replacement: 手順 3、 3の画像 2 Anker 2.4G Wireless Mouse Side Button Replacement: 手順 3、 3の画像 3
    • Pry the panels apart gently using a plastic opening tool or spudger.
    • Potential for device damage: In the pictures provided, a Phillips #0 screwdriver is used to pry open the mouse. It's important to note that this isn't proper procedure. Accidental internal damage to devices may occur when using improper prying tools. To avoid this, when prying open devices, always use plastic opening tools or spudgers.
  4. Anker 2.4G Wireless Mouse Side Button Replacement: 手順 4、 1の画像 1
    • After separating the halves, remove the housing wires from the white crimp headers to separate the upper and lower housing units of the mouse.
    • Potential for device damage: Pull as far up on the wire as possible to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse Side Button Replacement: 手順 5、 1の画像 1
    • Remove the two screws holding the board in place using a Phillips #0 screwdriver.
  6. Anker 2.4G Wireless Mouse Side Button Replacement: 手順 6、 1の画像 1
    • Remove the board from the housing unit and place it aside.
  7. Anker 2.4G Wireless Mouse Side Button Replacement: 手順 7、 3の画像 1 Anker 2.4G Wireless Mouse Side Button Replacement: 手順 7、 3の画像 2 Anker 2.4G Wireless Mouse Side Button Replacement: 手順 7、 3の画像 3
    • Left on the brown-colored bottom of the board, there are two black-and-white boxes. These are the side buttons.
    • Flip the board over to reveal the green-colored side.
    • Desolder the six silver pins to disconnect the side buttons.
    • Once desoldered, remove the old side buttons.
    • Resolder the pins of the new buttons onto the board.
終わりに
作成者
7人の作成者と共同で作成されました。
Andreas Apitz
メンバー登録日: 01/23/14
119 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S1G39
4 メンバー
16のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 17
今までの合計 847
