メインコンテンツにスキップ
Anker 2.4G Wireless Mouse Scroll Wheel Replacement
必要な工具と部品
  1. Anker 2.4G Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: 手順 1、 1の画像 1
    • Remove the stickers from the bottom of the mouse to have access to the screws, The stickers are shown in the picture by the red rectangles.
  2. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 手順 2、 1の画像 1
    • Use a Phillips #00 to remove the 4 screws shown by the red circles in the picture.
  3. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 手順 3、 2の画像 1 Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 手順 3、 2の画像 2
    • Using a plastic opening tool or spudger, on the center of the mouse, separate the upper and lower board.
  4. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 手順 4、 1の画像 1
    • Remove the wires from the white crimp headers, separating the upper and lower housing units of the mouse. Avoid pulling the wires too hard to prevent them from breaking.
    • Don't pull the wires too hard, as they might break.
  5. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 手順 5、 2の画像 1 Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 手順 5、 2の画像 2
    • Pull the scroll wheel put parallel to the board.
    • This may take some force to remove. Pull the scroll wheel out parallel to the board rather than perpendicular to it.
    • Replace/clean if needed.
    • If your mouse still does not work after this step, then continue to the next instruction.
  6. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 手順 6、 1の画像 1
    • Desolder the three pins, then solder in the replacement part.
終わりに
作成者
12人の作成者と共同で作成されました。
Vincent Lee
メンバー登録日: 01/23/14
361 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S1G39
4 メンバー
16のガイドは作成済み
コメント 1 件
Hi Vincent, could you please help me with finding a place where this rotation sensor can be bought. I'm not even sure how this part is called so searching for it is quite tricky.
Cheers,
Michal
Michal Rorat - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 10
過去 30 日: 37
今までの合計 8,449
