はじめに
This mouse was designed with usability in mind taking little to no effort to fix anything.
  1. Use the screwdriver to remove the stickers hiding the screws marked in red.
    • Use the screwdriver to remove the stickers hiding the screws marked in red.
  2. Remove the 4 screws to continue.
    • Remove the 4 screws to continue.
  3. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  4. Pry the center of the mouse apart to separate the upper and lower housing of the boards. Pry the center of the mouse apart to separate the upper and lower housing of the boards.
    • Pry the center of the mouse apart to separate the upper and lower housing of the boards.
  5. Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
    • Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
    • Don't pull the wires too hard, as they might break.
  6. Pull the Scroll wheel, in red, to the left to remove it. This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
    • Pull the Scroll wheel, in red, to the left to remove it.
    • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
    • Replace/clean if needed.
    • If your mouse still doesn't work after this step, please continue onto the next step.
  7. Desolder these 3 pins and solder the replacement part in.
    • Desolder these 3 pins and solder the replacement part in.
まとめ
Vincent Lee
メンバー登録日: 2014年01月23日
361 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S1G39
4 メンバー
8のガイドは作成済み
コメント1件
Hi Vincent, could you please help me with finding a place where this rotation sensor can be bought. I'm not even sure how this part is called so searching for it is quite tricky.
Cheers,
Michal
Michal Rorat - 返信
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 77
今までの合計 4,646
