メインコンテンツにスキップ
Anker 2.4G Wireless Mouse Battery Replacement
  1. Anker 2.4G Wireless Mouse Battery Replacement, Battery: 手順 1、 1の画像 1
    • Remove the battery cover with a plastic opening tool, nylon spudger, or a fingernail.
  2. Anker 2.4G Wireless Mouse Battery Replacement: 手順 2、 1の画像 1
    • Remove the battery with a finger nail or a nonmetal tool.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Vincent Lee
メンバー登録日: 01/23/14
361 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S1G39
4 メンバー
16のガイドは作成済み
2 件のコメント
My Anker vertical wireless mouse uses 2 "AAA" batteries. It is Model TMI56G. Batteries are fresh. Dongle is new. The mouse worked fine with the dongle that was broken prior to the company sending me a replacement. The highest bar on the thumb side on the mouse comes on and glows red briefly when I turn the mouse on. There is no clear button on top of the mouse. I have Windows 10 and when I check my settings I keep getting an "ERROR CODE 10" FOR MY ANKER Mouse. My LOGITECH mouse works just fine when I plug into the same USB port. Could I have been sent the wrong dongle for my ANKER Mouse? Please advise.
Thank You,
Richard Johnson
mutantear@comcast.net
Rick Johnson - 返信
Any help would be appreciated. I need to return the LOGTECH mouse I'm now using to it's owner.
Thanks,
Rick
Rick Johnson - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 16
過去 30 日: 55
今までの合計 5,203
