メインコンテンツにスキップ
American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement
必要な工具と部品
  1. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the sandpaper disc: 手順 1、 1の画像 1
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
  2. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 2、 1の画像 1
    • Peel the hook-and-loop sandpaper disc off of the driver assembly.
  3. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the driver pad: 手順 3、 2の画像 1 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the driver pad: 手順 3、 2の画像 2
    • Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
    • Remove the driver pad from the sanding disc.
  4. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the sanding disc: 手順 4、 3の画像 1 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the sanding disc: 手順 4、 3の画像 2 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the sanding disc: 手順 4、 3の画像 3
    • Use a flathead screwdriver to pry off and remove the rubber plug in the center of the sanding disc.
  5. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 5、 2の画像 1 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 5、 2の画像 2
    • Slide a thin 22 mm wrench underneath the sanding disc and clasp it onto the flat part of the motor driveshaft to keep the driveshaft from turning.
  6. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 6、 2の画像 1 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 6、 2の画像 2
    • Use an 11 mm socket and socket wrench to remove the 16.5 mm-long bolt securing the sanding disc to the motor driveshaft.
    • Apply counter torque to the driveshaft wrench as you loosen the bolt to keep the sanding disc from spinning.
  7. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 7、 3の画像 1 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 7、 3の画像 2 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 7、 3の画像 3
    • Take two pry bars and insert them underneath the sanding disc as close to the driveshaft as possible.
    • Apply pressure to the pry bars in opposite directions to carefully pry the sanding disc off of the driveshaft.
    • Remove the sanding disc from the floor sander.
  8. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the bottom weight and cover: 手順 8、 1の画像 1
    • Repeat the previous seven steps to remove the other two sanding discs before continuing.
    • With all three sanding discs removed, use a 4 mm hex key to remove four 25.4 mm-long screws securing the bottom cover and bottom weight.
  9. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 9、 1の画像 1
    • Lift the bottom weight away from the sander.
  10. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 10、 3の画像 1 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 10、 3の画像 2 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 10、 3の画像 3
    • Pull the top edge of the bottom cover away from the sander until you have enough space to slide the cover out.
    • Slide the cover across the bottom of the sander, away from the wheels, and remove it.
  11. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement, Remove the dust fan: 手順 11、 1の画像 1
    • Remove the washer from the motor shaft.
  12. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 12、 3の画像 1 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 12、 3の画像 2 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 12、 3の画像 3
    • Pull the drive pad bearing straight off of the motor shaft.
    • You may not be able to remove the bearing with your hands. If this is the case, use a bearing puller to remove the bearing.
  13. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 13、 3の画像 1 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 13、 3の画像 2 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 13、 3の画像 3
    • Using snap ring pliers, pry the snap ring open and slide it off of the motor shaft.
    • Remove the snap ring.
  14. American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 14、 2の画像 1 American Sanders EZSand Orbital Sander 07163A 2017 Dust Fan Replacement: 手順 14、 2の画像 2
    • Slide the dust fan straight off of the motor shaft.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
195,318 ポイント
416のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 426
