はじめに
Use this guide to replace the motor in a Clarke Floor Sander 07163A 2012.
This guide shows the removal of one motor, but the process is the same for any of the other motors.
必要な工具と部品
Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
Remove the driver pad from the sanding disc.
Use a flathead screwdriver to pry off and remove the rubber plug in the center of the sanding disc.
Repeat the previous seven steps to remove the other two sanding discs before continuing.
With all three sanding discs removed, use a 4 mm hex key to remove four 25.4 mm-long screws securing the bottom cover and bottom weight.
Using snap ring pliers, pry the snap ring open and slide it off of the motor shaft.
Remove the snap ring.
Use an 11 mm socket to remove the four 22.8 mm-long screws securing the motor.
Lift the top of the latch securing the handle assembly to the sander and push it back against the sander.
Make sure the hook on the latch is clear of the small metal tab on the sander.
Repeat this step for all three latches securing the handle assembly.
Use a Phillips #2 driver to remove three 22.1 mm-long screws securing the motor cover to the sander. There is one screw on each side of the sander.
