メインコンテンツにスキップ
American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement
必要な工具と部品
  1. American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement, Separate the handle: 手順 1、 1の画像 1
    • Before you begin, make sure the sander is turned off and unplugged.
    • Use a 3/16" hex key or driver bit to remove the six 23.4 mm-long screws holding the two halves of the handle enclosure together.
  2. American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement: 手順 2、 3の画像 1 American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement: 手順 2、 3の画像 2 American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement: 手順 2、 3の画像 3
    • The rear half of the enclosure is bolted to the handle support, so the front half will be removed first.
    • Pull the front half of the enclosure straight away from the rear half to separate the enclosure.
    • If the interlock assembly comes out with the front half of the enclosure, detach it and place it back into the rear half.
    • Remove the front half of the handle enclosure.
  3. American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement, Unplug the interlock assembly: 手順 3、 3の画像 1 American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement, Unplug the interlock assembly: 手順 3、 3の画像 2 American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement, Unplug the interlock assembly: 手順 3、 3の画像 3
    • Pull the wires connected to the interlock assembly straight out of their connectors.
    • Keep track of where each wire connects on the interlock assembly.
  4. American Sanders EZSand Orbital Sander 07163A 2012 Interlock Assembly Replacement, Remove the interlock assembly: 手順 4、 1の画像 1
    • After all wires are disconnected from the interlock assembly, remove the interlock assembly from the handle.
終わりに
Miles Robinson
メンバー登録日: 03/04/19
896 ポイント
7のガイドは作成済み
チーム
The Home Depot The Home Depot人のメンバー
Community
14,221 メンバー
75のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 109
