はじめに
Sometimes the Micro USB Jack will stop working properly and may need replacing. This guide requires use of a Soldering Iron and should only be attempted by those with soldering experience. If soldered incorrectly, your device may be permanently damaged.
必要な工具と部品
Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
この手順で使用する道具:Tweezers$4.99
Using a Phillips #1 screwdriver, remove the two black 10mm screws on the interior of the case on the side with the USB and AUX inputs.
Use the plastic opening tool and tweezers at different points to work the audio input casing off.
2 の人々がこのガイドを完成させました。
1件のガイドコメント
that's awesome didn't i would find a tutorial but here it is. thanks man. What kind of usb connector do i use.
