メインコンテンツにスキップ
AmazonBasics B00Q3KFX8U Motor Replacement
必要な工具と部品
  1. AmazonBasics B00Q3KFX8U Motor Replacement, Drive Gear: 手順 1、 1の画像 1
    • Remove the shredder assembly from the paper scrap bin.
  2. AmazonBasics B00Q3KFX8U Motor Replacement: 手順 2、 1の画像 1
    • Remove the two 10mm PH1 screws holding the small black panel in place.
  3. AmazonBasics B00Q3KFX8U Motor Replacement: 手順 3、 2の画像 1 AmazonBasics B00Q3KFX8U Motor Replacement: 手順 3、 2の画像 2
    • Remove the six 14mm PH1 screws holding the bottom cover in place.
    • Remove the cover by lifting straight upwards.
    • One of the screws will be hidden beneath a warranty sticker. Simply push the head of the screwdriver through the sticker to access the screw.
  4. AmazonBasics B00Q3KFX8U Motor Replacement: 手順 4、 1の画像 1
    • Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
    • The blades are sharp. Coming into contact with them may result in injury.
  5. AmazonBasics B00Q3KFX8U Motor Replacement: 手順 5、 2の画像 1 AmazonBasics B00Q3KFX8U Motor Replacement: 手順 5、 2の画像 2
    • Remove the five 8mm PH2 screws from the bracket holding the gears in place.
  6. AmazonBasics B00Q3KFX8U Motor Replacement: 手順 6、 1の画像 1
    • Use a metal spudger to pry the bracket from the main shredder assembly.
    • If the bracket is attached too tightly for the spudger, carefully use a metal screwdriver to pry it loose.
  7. AmazonBasics B00Q3KFX8U Motor Replacement: 手順 7、 2の画像 1 AmazonBasics B00Q3KFX8U Motor Replacement: 手順 7、 2の画像 2
    • Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
  8. AmazonBasics B00Q3KFX8U Motor Replacement, Motor: 手順 8、 1の画像 1
    • Remove the four 18mm PH2 screws holding the motor to the main shredder assembly.
  9. AmazonBasics B00Q3KFX8U Motor Replacement: 手順 9、 1の画像 1
    • Disconnect the motor from the motherboard by either clipping the wires, or using a soldering iron to disconnect the wires directly at the board.
    • To reattach the motor, solder the wires back together, or to the motherboard depending on how you removed them.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
William Foley
メンバー登録日: 03/25/16
548 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 1-3, Miles Spring 2016 UMass Dartmouth, Team 1-3, Miles Spring 2016人のメンバー
UMASSD-MILES-S16S1G3
2 メンバー
4のガイドは作成済み
コメント 1 件
Do you sell motor?
Binh - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 19
今までの合計 758
