メインコンテンツにスキップ
AmazonBasics B0050BPWBQ Shredding Gears Replacement
必要な工具と部品
  1. AmazonBasics B0050BPWBQ Shredding Gears Replacement, Front and Back Panel Disassembly: 手順 1、 2の画像 1 AmazonBasics B0050BPWBQ Shredding Gears Replacement, Front and Back Panel Disassembly: 手順 1、 2の画像 2
    • The unit head needs to be switched to the off position and unplugged before any disassembly.
    • When removing screws in the following steps, make sure the unit is resting on a flat surface because pieces will easily come apart.
    • Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
  2. AmazonBasics B0050BPWBQ Shredding Gears Replacement: 手順 2、 2の画像 1 AmazonBasics B0050BPWBQ Shredding Gears Replacement: 手順 2、 2の画像 2
    • Upon removal of the next screws, the front panel and the shredding component attached to it will fall apart from the back panel so have the unit resting on a flat surface.
    • Remove two 50 mm Phillips #1 screws from the middle of the underside of the head unit.
  3. AmazonBasics B0050BPWBQ Shredding Gears Replacement: 手順 3、 1の画像 1
    • Lay the back panel away from the front panel on a flat surface.
    • The back panel will be light because it is only the plastic, while the front panel will be heavy with the shredding component attached to it.
  4. AmazonBasics B0050BPWBQ Shredding Gears Replacement: 手順 4、 2の画像 1 AmazonBasics B0050BPWBQ Shredding Gears Replacement: 手順 4、 2の画像 2
    • Find the green control board that is located next to the shredding motor.
    • Remove two 11 mm Phillips #1 screws located on opposite sides of the control board.
    • You may need to move wires over to find the screws.
  5. AmazonBasics B0050BPWBQ Shredding Gears Replacement, Shredding Gears: 手順 5、 2の画像 1 AmazonBasics B0050BPWBQ Shredding Gears Replacement, Shredding Gears: 手順 5、 2の画像 2
    • Unit may be greasy so you may want to grab paper towels/rag when completing these next steps.
    • Locate the large white gears on the side of the shredding unit.
    • Remove two 15 mm Phillips #1 screws that hold the motor in place.
  6. AmazonBasics B0050BPWBQ Shredding Gears Replacement: 手順 6、 3の画像 1 AmazonBasics B0050BPWBQ Shredding Gears Replacement: 手順 6、 3の画像 2 AmazonBasics B0050BPWBQ Shredding Gears Replacement: 手順 6、 3の画像 3
    • Locate the three washers on the metal triangle piece.
    • Remove the three washers using two metal spudgers. To do this, place one spudger on each of the open ends of the washer. Push down with both spudgers at the same time to pop the washer off the gear.
    • Pull the metal triangle away from the gears.
  7. AmazonBasics B0050BPWBQ Shredding Gears Replacement: 手順 7、 2の画像 1 AmazonBasics B0050BPWBQ Shredding Gears Replacement: 手順 7、 2の画像 2
    • Remove the middle gear from the shredding unit.
    • Remove the top gear that was located under the middle gear.
  8. AmazonBasics B0050BPWBQ Shredding Gears Replacement: 手順 8、 2の画像 1 AmazonBasics B0050BPWBQ Shredding Gears Replacement: 手順 8、 2の画像 2
    • Remove the washer on the last gear using two metal spudgers. Again, place one spudger on each of the open ends of the washer. Push down with both spudgers at the same time to pop the washer off the gear.
    • Pull the last gear away from the metal shredding unit.
終わりに
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Natalie Meert
メンバー登録日: 02/11/16
678 ポイント
4のガイドは作成済み
チーム
IUPUI, Team 2-4, Baechle Spring 2016 IUPUI, Team 2-4, Baechle Spring 2016人のメンバー
IUPUI-BAECHLE-S16S2G4
4 メンバー
8のガイドは作成済み
6 件のコメント
Where did you buy the replacement gears?
DIY Security Guy - 返信
I agree, where do you get the replacement gears? I’ve looked everywhere!
CSHardware - 返信
Taking the shredder apart is easy, finding and procuring the replacement gears is next to impossible…. It would be worth 130 points if you provided information on that.
Paul Williams - 返信
I am also looking for parts.
Carl Young - 返信
I need the circuit to determine the valué of a resistance that burned
Ximena A. Oyarzún González - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 29
過去 30 日: 67
今までの合計 10,569
