はじめに
The On/Off switch located on the front panel may become damaged and no longer function correctly. With a dysfunctional switch, you may not be able to get the shredder to operate.
必要な工具と部品
Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
Pull the front panel away from the shredding unit.
Locate the black On/Off switch attached to the front panel where the control board was once attached.
Squeeze the wings of the On/Off switch from the inside of the front panel to detach it from its slot in the panel.
ある他の人がこのガイドを完成しました。
