メインコンテンツにスキップ
Amazon Kindle DX Previous Page Key Replacement
必要な工具と部品
  1. Amazon Kindle DX Previous Page Key Replacement, Battery: 手順 1、 1の画像 1
    • Flip the Kindle so the back is facing upwards.
  2. Amazon Kindle DX Previous Page Key Replacement: 手順 2、 1の画像 1
    • Push an opening tool against the bottom cover edge of the device. Move the tool's edge around the bottom plastic piece to pop it open.
  3. Amazon Kindle DX Previous Page Key Replacement: 手順 3、 1の画像 1
    • Remove the plastic piece.
  4. Amazon Kindle DX Previous Page Key Replacement: 手順 4、 2の画像 1 Amazon Kindle DX Previous Page Key Replacement: 手順 4、 2の画像 2
    • Remove two 40 mm screws (one on each corner) using a Phillips #00 screwdriver.
  5. Amazon Kindle DX Previous Page Key Replacement: 手順 5、 2の画像 1 Amazon Kindle DX Previous Page Key Replacement: 手順 5、 2の画像 2
    • Use the edges of the opening tool, get in between the seams of the front and back panel, and use the tool to separate the pieces. Once loose, lift back panel off of the device.
  6. Amazon Kindle DX Previous Page Key Replacement: 手順 6、 2の画像 1 Amazon Kindle DX Previous Page Key Replacement: 手順 6、 2の画像 2
    • Remove two 30 mm screws securing the battery with a Phillips #00 screwdriver.
  7. Amazon Kindle DX Previous Page Key Replacement: 手順 7、 2の画像 1 Amazon Kindle DX Previous Page Key Replacement: 手順 7、 2の画像 2
    • Remove the battery from the device.
  8. Amazon Kindle DX Previous Page Key Replacement, Previous Page Key: 手順 8、 3の画像 1 Amazon Kindle DX Previous Page Key Replacement, Previous Page Key: 手順 8、 3の画像 2 Amazon Kindle DX Previous Page Key Replacement, Previous Page Key: 手順 8、 3の画像 3
    • Remove five 30 mm screws from the midframe using a Phillips #000 screwdriver.
  9. Amazon Kindle DX Previous Page Key Replacement: 手順 9、 1の画像 1
    • Remove the midframe to reveal the motherboard.
  10. Amazon Kindle DX Previous Page Key Replacement: 手順 10、 2の画像 1 Amazon Kindle DX Previous Page Key Replacement: 手順 10、 2の画像 2
    • Remove the "previous page" button from the side function keys using a pair of tweezers.
終わりに
作成者
9人の作成者と共同で作成されました。
Lori White
メンバー登録日: 09/28/16
557 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 1-5, Cagle Fall 2016 USF Tampa, Team 1-5, Cagle Fall 2016人のメンバー
USFT-CAGLE-F16S1G5
3 メンバー
8のガイドは作成済み
2 件のコメント
The title says “keyboard”, this is button replacement…………….
Robert Clayworth - 返信
The title says “keyboard” replacement. This is button replacement…………….
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 1,127
