はじめに
If you've tried replacing the batteries to your remote, and still experience issues. You can replace the remote control's motherboard with this guide.
You will be removing multiple screws with this fix. Be sure to keep the removed screws inside a container since they are very small and easy to misplace.
必要な工具と部品
Turn the remote control over to show its back and place your index finger in the tab. Squeeze gently to open the battery cover.
Lift the battery cover up to expose the batteries.
Locate the four 3.6 mm Phillips J#00 screws found under the back panel of the remote control and remove them.
5 の人々がこのガイドを完成させました。
3 件のコメント
Hello,
step 5 is wrong! There are no pins but screws!
You need to disconnect the upper piece (infrared sensor) first. Underneath you will find two more screws. Then you can open the case easily.
The circuit board can not be fixed instead of replaced. Understand might be cheaper to replace
This was useful to me to find a location I could attach a lanyard to the remote. It is so small it keeps disappearing.
