はじめに
Are some of the buttons on your remote unresponsive? Use this guide to replace the button panel on the remote control.
Make sure to keep the removed screws inside a container, or on a magnetic mat so they don't get misplaced.
必要な工具と部品
Turn the remote control over to show its back and place your index finger in the tab. Squeeze gently to open the battery cover.
Lift the battery cover up to expose the batteries.
Locate the four 3.6 mm Phillips J#00 screws found under the back panel of the remote control and remove them.
Locate the black plastic tab at the top end of the button panel, grab it with your fingers and pull back to separate the button panel from the remote control's case.
5 の人々がこのガイドを完成させました。
3 件のコメント
I too popped it open with force and found the 2 nuts pulled out of their sockets. I was able to remove the screws from the case, then re-insert the screws into the nuts and punch them (hard) back into the little socket holes. They stuck fast, and didn’t spin when I reassembled the remote.
