メインコンテンツにスキップ
Amazon Fire TV Loose Contact in the Battery Compartment
必要な工具と部品
  1. Amazon Fire TV Loose Contact in the Battery Compartment, Open the battery compartment: 手順 1、 2の画像 1 Amazon Fire TV Loose Contact in the Battery Compartment, Open the battery compartment: 手順 1、 2の画像 2
    • Place the remote control with the battery cover facing up. Pull the tap with your fingernail and flip up the battery cover.
    • Remove the battery cover.
  2. Amazon Fire TV Loose Contact in the Battery Compartment, Check the cause of the failure: 手順 2、 1の画像 1
    • Before this repair is performed, it has to be checked, if the failure described in this repair guide exists. Check, if the batteries are not empty (in doubt please use new batteries).
    • Strongly press both batteries to the top of the remote control with a screwdriver (or your fingernails). See arrows in the image.
    • Wait 10-15 seconds in order to let the remote control reconnect with the Amazon Fire TV.
    • Check if the remote control now works properly with the Amazon Fire TV. Do not handle the remote control jerkily but very careful and pay attention that the batteries do not fall out.
    • If the remote control now works properly, continue with this repair guide. If not, stop the repair guide because there might be another root cause of the malfunction.
  3. Amazon Fire TV Loose Contact in the Battery Compartment, Remove the batteries: 手順 3、 2の画像 1 Amazon Fire TV Loose Contact in the Battery Compartment, Remove the batteries: 手順 3、 2の画像 2
    • First pull out the front battery by lifting it, then pull out the second battery.
  4. Amazon Fire TV Loose Contact in the Battery Compartment, Explanation of the root cause of the failure: 手順 4、 1の画像 1
    • Information: On both sides in the battery compartment there are battery-fixations made of rubber. You can easily feel them with your finger because they are softer than the plastic housing.
    • Information: These rubber battery-fixations can be that strong or thick, that the batteries get stuck and therefore the internal spring, which presses the batteries on the electrical contact, is too weak in relation. This is the cause why the remote control is sometimes not working.
    • The next step explains how to fix the problem.
  5. Amazon Fire TV Loose Contact in the Battery Compartment, Cut off the rubber battery-fixing: 手順 5、 3の画像 1 Amazon Fire TV Loose Contact in the Battery Compartment, Cut off the rubber battery-fixing: 手順 5、 3の画像 2 Amazon Fire TV Loose Contact in the Battery Compartment, Cut off the rubber battery-fixing: 手順 5、 3の画像 3
    • If this step is executed, it might happen that the batteries will afterwards permanently rattle when using the remote control!
    • Set the cutter knife carefully to the red bordered part of the rubber battery-fixing.
    • Lead the cutter knife carefully along the longitudinal direction of the remote control and cut off only the red bordered part of the rubber battery-fixing. See picture.
    • Attention! Never touch the bottom of the battery compartment with the cutter knife because this is the circuit board of the remote control electronics. Any scratching of the circuit board can lead to total damage of the remote control.
    • Alternatively you can use a small side cutter instead of the knife to cut off the battery-fixing.
    • Typically the rubber battery-fixing is now weakened so much, that in relation the internal spring is strong enough to press the batteries on the electrical contact regardless of the orientation of the remote control. If not: Cut off symmetrically the rubber battery-fixing on the opposite side.
  6. Amazon Fire TV Loose Contact in the Battery Compartment, Put in the batteries and close the cover: 手順 6、 1の画像 1
    • Put in the batteries in the correct direction (see schematic illustration on the ground of the battery compartment).
    • Put in and close the battery cover.
    • Check the function of the remote control. If it does not work, see the note in step 5.
    • You're done!
終わりに
I hope that this repair guide was also helpful for you to fix the problem.
2 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
de en
100%
PMBさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
PMB
メンバー登録日: 03/01/19
269 ポイント
1ガイドが承認済み
コメント 1 件
the prong inside my battery compartment is stuck inside they moved fine when changing batteries
raidermom73 - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 37
過去 30 日: 217
今までの合計 14,442
