はじめに
This guide will walk you through the step-by-step procedures to remove and replace the speaker in your Amazon Fire TV Cube. These steps are simple, however some require considerable force. To complete this replacement you will need a small screwdriver and opening tool.
必要な工具と部品
Using a metal spudger, push down between the edge seals on the base and pry off the base.
2 の人々がこのガイドを完成させました。
