はじめに
Note that before removing the Micro-USB port you will need to remove the battery.
必要なもの
Press the small suction cup just above the home button.
While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
Unscrew the 1mm screw on the top left side of the phone
Maneuver the bracket off slowly
3 の人々がこのガイドを完成させました。
2 件のコメント
Incomplete...
